PS pump or Hydroboost? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-16-2013, 05:38 PM Thread Starter
My 2001 F250 is making a whining sound from the PS pump whenever I turn the steering wheel. The brake pedal is also hard to press and makes a fart sound when you do press it. Steering is fine as far as turning the wheel, it turns freely with no hard steering, but the steering is all over the place when driving, you constantly have to adjust the wheel to keep going straight.
I have been told by one mechanic that it is the PS pump and by one mechanic that it is the hydroboost. The mechanic that thinks it is the PS pump said that the PS pump is not putting out enough pressure to the hydroboost.
Anyone have a similar issue and what did you do to fix?
Atem2144 is offline
post #2 of 12 Old 06-17-2013, 07:15 PM
russtwentyfour's Avatar
This helped mine so may work to help yours.
How to: Power Steering Flush (Video)
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 12 Old 06-23-2013, 04:52 PM Thread Starter
Thanks for the info. I flushed the system with Mercon V and it works great now. I think the previous owned used power steering fluid. I can't believe that it was that simple of a repair. Thanks again.
Atem2144 is offline
post #4 of 12 Old 06-25-2013, 11:20 AM
merc123's Avatar
Whining sound: power steering pump more than likely.
Hard brakes: hydroboost
Steering all over the place: Steering box
I had the whining and "slack" in the steering and replaced the box and had no issues. It actually got to the point one day where I lost brakes and steering because of the box. Replaced it with a Redhead steering box and haven't had any issues since.
'00 F350
Mods: Nitto Trail Grapplers, Diamo 17 Karat wheels, Red-head Steering box, Autometer gauges, Tru-Cool #4739 trans cooler, BFxenon HID lights
'03 Mustang GT
Mods: A bunch. -->
merc123 is offline
post #5 of 12 Old 07-06-2013, 07:19 PM
i just ran in to this issue...last weekend when pulling my boat out of the water i noticed my brakes getting hard or spongey and making a noise when pressing on them. then by the time i got home (about 8 miles) i was also getting a whine when turning the wheel hard. upon examination i noticed something leaking all over my driver side fender area, axle and spring, plus it was all down the side of my boat i could see droplets coming off my high pressure line off the power steering pump and thought that was it.
Just now i got down in there to check things out. I can move my high pressure line coming from the power steering with my finger but the fitting itself is snug...its loose where the hard line comes out of the fitting and 90s through a square and on to the rest of the hard line before entering into the rubber line.
I checked the lines and wiped everything down, checked my power steering fluid level and it still seemed fine...not like it had been dumping out enough to cover everything AND the side of my boat. started her up and started turning the wheel. still have the loud *** whine but after a couple turns i could not determine where a leak was....
ANY HELP would be greatly appreciated...not sure where to start at this point...
zac93218 is offline
post #6 of 12 Old 07-06-2013, 07:57 PM
Quoted: 768 Post(s)
You'll need someone moving the wheels back n forth while you get in there and look for the leak. Start there. The pump itself is pretty cheap n fairly easy to replace with the correct puller to remove the pulley.
Corey@CNCFAB is offline
post #7 of 12 Old 07-06-2013, 08:21 PM
before posting this i did have my girlfriend move the steering wheel back and forth while i searched for a leak. she only did it a hand full of times and i did not find anything but i KNOW it has to be leaking somewhere! so im gonna clean and wipe everything down and try it again. this time ill just spend a good 10 minutes of having the steering wheel turned until i find the leak! i will report back when i figure out where it is coming from.
zac93218 is offline
post #8 of 12 Old 07-14-2013, 05:36 PM
is there a forum DYI info on how to change out the power steering pump? I cant find one unless im looking in the wrong place
zac93218 is offline
post #9 of 12 Old 07-24-2013, 07:33 PM
still cant find anything on the steps for removing/replacing the power steering pump...is there a DIY anywhere on this forum!?
zac93218 is offline
post #10 of 12 Old 07-24-2013, 08:07 PM
Quoted: 768 Post(s)
Its pretty easy. You just need to borrow the correct puller at autozone or similar parts store to remove the pulley first. Once you get that off its rather easy and a couple hoses.
