Cruise Control problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-14-2013, 07:19 PM Thread Starter
rascal's Avatar
My cruise control is no longer working after I was doing some work and the connector at the end of the brake booster came unplugged. Plugged in back in but still having an issue.
Ran the KOER switch test in AE and here is what I got:
P1536 Parking Brake Switch circuit
P0220 Throttle / Pedal Position Sensor / Switch B circuit
P0704 Clutch Switch Input Circuit Malfunction
P0571 Cruise Control / Brake Switch A Circuit
P0703 Torque Converter / Brake Switch B circuit
P0565 Cruise Control On Signal
P0566 Cruise Control Off Signal
P0567 Cruise Control Resume Signal
P0568 Cruise Control Set Signal
P0569 Cruise Control Coast Signal
I am looking at the wiring diagram for a 2000 7.3 cruise control system and based on these codes I would guess it is still and issue with the sensor on the brake booster. I plugged it back after it came unplugged some how when I was doing my upgrades(RR, turbo, exhaust, instake). Should I replace the sensor? The connector looks ok but my cruise control was working fine before.
Any thoughts/suggestions?
Thanks in advance
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #2 of 4 Old 07-12-2013, 12:05 AM
Sgt. Stroker's Avatar
Send a message via AIM to Sgt. Stroker Send a message via Skype™ to Sgt. Stroker
I'm certain there was a recall for our CC
1999 F-250
TS 4 Pos Chip(50-75-100-140)
AFE air intake with K&N filter
5" Exhaust
3 Pillar pod (Pyro, EGT, Boost)
Sgt. Stroker is offline
post #3 of 4 Old 07-12-2013, 06:07 AM Thread Starter
rascal's Avatar
The code were because I did not run through the switches while doing the switch test.
My cruise control is working now. One of the connections was not "good'n tight"!
Thanks!
Rascal
rascal is offline
post #4 of 4 Old 08-12-2013, 03:16 PM
OZ 4X4's Avatar
Hi Guys
i am havin a simular problem but mine will work for 5mile then turn its self off then i turn it bak on and might cut strait off or work for hours think this could be a loose conector but were do i find a diagram for the cruise control wiring
2002 f-250 supercab 7.3 L turbo
cheers guys
oz
OZ 4X4 is offline
