Vacuum help and digrams needed - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-12-2013, 07:45 PM Thread Starter
I fixed my slow start problem (replaced the starter...) and now the A/C only blows out the defrost. I calculate it is a vacuum loss. I looked for a diagram that may have been posted and do not see one. I have manual hubs on the front and figure they are no longer connected up top.
Where is the pump located and would someone have a diagram handy to post?
Thanks,
Mike
2000 Excursion XLT w/ leather
Purchased stock. Now consists of PHP Gryphen Edge CTS programmer, MBRP 4" turbo back, AFE Stage II CAI and BTS valve body swap. Rear RAS load handling helpers. Helwig rear anti-roll bar. Soon to install is a 31 row 6.0 tranny cooler.
(Waiting to pull my 2 Buicks to shows and races)
beamer is offline
post #2 of 6 Old 06-14-2013, 09:40 AM
Bubba88's Avatar
I'll see if I can dig anything up. I'll let ya know.
Nathan --
'04 CCSB FX4 with some go-go parts from the performance section of AutoZone
Bubba88 is offline
post #3 of 6 Old 06-14-2013, 09:42 AM
Pump is on the passenger side of the engine compartment towards the fire wall it is about the size of your fist is black
2002 F-350 7.3 ex-cab short bed Beans 6 Pos
6 inch lift, 35,s, 4 Inch Turbo Back, 6637 intake
Foil delete, 05 harley front end, 08 Tailights
Tinted cab lights, and this and that and this
Z-STROKE is offline
post #4 of 6 Old 06-14-2013, 09:46 AM
Found this picture on google.
Z-STROKE is offline
post #5 of 6 Old 07-28-2013, 04:43 AM Thread Starter
Everything started working again for no reason. On a trip over to Valdosta, it happened during driving. Once I got home, I went out to check out what is going on.
I turned the key on (did not start to hear). The pump was running and running. I looked over the hoses and realized that only one line went outbound (there are 4 lines total, but they all connect together). I wiggles the hoses around a little right a the pump to see if there were any that was loose. About 30 seconds of messing with them, the pump shut off. I went into the cab and the vents had air blowing out of them again.
So, I either have a leak right at the pump that I fixed by wiggling the hoses arouns (but everything is tight and I could not really move anything), or the pump is just not pulling a vacuum correctly and me moving it around caused the internals to be jarred around to start drawing vacuum.
Do these pumps act up like this?
Looking for ideas. I can't fix it when it is working.
Thanks all,
Mike
beamer is offline
post #6 of 6 Old 07-28-2013, 06:39 AM
timmyboy76's Avatar
buddy of mine, had same thing. I found the "vacuum" connection to be unplugged..(behind glovebox..white/black hoses connection)
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
