Trans doesn't want to shift down - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-10-2013, 04:20 PM Thread Starter
2000 f550 2wd. Fluid is full and unburnt. I have a 6.0 cooler and a deep pan. It's a reman jasper with about 30k on it.
The problem is that it doesn't want to shift down out of overdrive unless you get fairly hard on the throttle. For instance if you're merging on to an on ramp or in traffic, and you ease on the throttle it will rev a bit then go back into high gear. If you get on the throttle hard then it will shift fine.
From a stop it goes down into first by itself and shifts fine up to overdrive. It doesn't seem to slip and shifts good through the gears.
Torque converter?
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #2 of 6 Old 06-11-2013, 10:14 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
From what you're describing, I don't see a problem
I have a Jasper and I can relate to it not wanting to shift out of overdrive when slowly getting into the pedal but it torques right up to speed, no problem. If you goose it then it will downshift and rocket forward.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 6 Old 06-11-2013, 10:22 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Sounds like its just holding the gear for hopes of increased mpgs. I'm sure a custom tune could change it though.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 6 Old 06-12-2013, 02:48 AM Thread Starter
No there's definitely something wrong. It's more like it is trying to decide what gear it wants. In town it tries to jump between gears a lot when you're going a steady speed or under light accel. Some where around 20mph or so I'd say.
I called jasper to start a warranty claim and they had me check the plug on the tranny for fluid on it. It seemed to be a little wet but I'm not positive. I cleaned it and put it back in after checking for bent pins. I also changed the fluid just to be sure of the cleanliness of the fluid and it was time for a change anyway. The fluid was very clean and not burnt at all. Only a slight amount of shavings on the magnetic drain plug. It doesn't seem to have any more wear than normal.
Did all that and today it's still acting the same. The o/d light is now flashing so I pulled the codes and got:
P0733
P0732
P0717
P0715
P0718
I'm driving so I can't research much until I get home today, but that seems to point to the speed sensors.
Any ideas?
2000 F550 CC 2WD
Schnot is offline
post #5 of 6 Old 06-15-2013, 08:12 AM Thread Starter
Update.
I pulled all the wiring out from under the truck and found the front speed sensor's wiring to be in bad shape. Ford doesn't sell a pig tail for it so luckily the '02 parts cab that I have in the yard was an auto. Swapped some plugs, fixed some chaffed wires, and put in a new front sensor for good measure.
Problem solved.
Side note; jasper gave me the direction to start with the front speed sensor, so shout out to them for their good service.
2000 F550 CC 2WD
Schnot is offline
post #6 of 6 Old 06-15-2013, 09:41 AM
Quoted: 17 Post(s)
Glad to hear
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
