3rd water pump in 55,000 miles! Cracked coolant res? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-08-2013, 12:46 PM Thread Starter
ScottyP5947's Avatar
Wow, I am going on a trip coming up real soon... and when going over my truck I discovered I was a little low on coolant. I went looking for the source of the leak and found a crack in my coolant res and then I found coolant under the nose of the water pump!!! I changed the pump when I bought it at 100 k miles, then changed it again around 140k and now I have this leaker at 155k! I put in a NAPA pump so it's warrantied. I installed a coolant filter and it hasn't clogged one filter yet so I don't think it's that. I would guess the only thing left would be the fan?? Common cause of wasting pumps? So I have to replace the fan, what does that cost?? Any fast options?
What about having a dealer do the pump because I don't have much time? Any idea how many hours they charge for that?
What about the crack in the res? Anyone's res look like this? Should I worry??
Damn this sucks. Thanks for advice -
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #2 of 4 Old 06-08-2013, 06:55 PM Thread Starter
Posting to hopefully help someone in the future - Today I called around to a few dealers that had parts counters open and they all immediately suggested replacing the fan clutch. It's a spendy part, 329 bucks or so. I picked up a res too, 96 bucks. Good thing the water pump is covered by NAPA warranty. If I wasn't in a hurry I would have set up some type of electric fan setup.
As for the crack in the res, you can see that the red coolant was deep in that crack so I wanted to play it safe there too - it is holding pressure so...
I had to jump on the parts today because the dealers were closed tomorrow and I really didn't want to wait until Monday!
Anyone else replace the fan clutch to fix this? Seems like an insanely high priced part to me. Maybe it will give me better MPG!
Thanks -
SCott
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
post #3 of 4 Old 06-08-2013, 07:14 PM
Quoted: 13 Post(s)
Feedback Score: 3 reviews
maybe info too late but my local autozone had the fan for a little less than $200. hopefully that fixes the problem
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 4 Old 06-09-2013, 10:16 AM Thread Starter
Thanks for the info! I'm going with the motorcraft parts and putting it back together today. Anyone have experience with the one piece thermostat + gasket??? Can you re-use these? It seems good but I am not a fan of re-using gaskets. Can't find a one piece anywhere around me, and I won't put in the old style two part gasket. I can probably grab one from the ford dealer tomorrow morning.
Reuse or no?>
Scott
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
