Cruise control not working after s366 turbo instal - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-05-2013, 07:23 PM Thread Starter
88kevina's Avatar
After I installed the new turbo set up I lost my cruise control. I don't know how the cruise control works and got to thinking it might be to do with something I took off to put on the new set up. Thanks in advance.
2000 F-250 4x4 ext.cab 6-speed
South Bend Clutch, Pyro & Boost, 6637, 5" Exhaust, CCV, FRX, 203* T-Stat, Coolant Filter, Bypass Oil Filter, 5/8th Fuel Pickup, Pre-Pump Filter, Melling Lpop, Stealth Srp 1.1, Swamps IDM, S366, AND Tunes from Jody(80/100/120)
"Speak softly, but carry a big stick" T.Roosevelt
KCCO
88kevina is offline
post #2 of 3 Old 06-05-2013, 11:16 PM
CSIPSD's Avatar
You bumped something, more then likely one of the connectors by the brake booster.
Nothing you remove to install the turbo can cause that issue, nothing in the valley has ANYTHING to do with the cruise.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 3 Old 06-06-2013, 08:49 AM Thread Starter
88kevina's Avatar
Thanks for the reply. I didn't think it had anything to do with cruise. But I've been going mad looking for a loose wire. Looks like I may end up in the looney bin before I get the cruise to work lol
KCCO
88kevina is offline
