Ok so I thought my master cylinder was leaking but I keep getting low on power steering fluid causing my pump to whine so I put more fluid in and it goes away but the only place it's leaking is between the master cylinder and the booster..and my brake fluid isn't getting lower and I haven't noticed much difference in my pedal so what should I do?? Any ideas? Maybe one of y'all have had the same problem..
Sent from AutoGuide.com App
