Radio won't shut off??? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-28-2013, 03:42 AM Thread Starter
Powerstroke_21's Avatar
Hey guys last night I went over to a friends house and hung out for a bit then I left and got home and pulled in the driveway and let it idle for a few minuets (only lives 4-5 miles away) and when I shut the truck off the radio shut off but this morning I walked out to start it for work and the drivers door wouldn't unlock (using the key fob or the key) so I walked over to the passenger side and unlocked it with the key and noticed my radio was on. The truck started fine this morning then I drove to work and pulled in and let it idle then turned the truck off and the radio stayed on again. I checked the ignition to make sure that it was off and it was so idk what's going on. Also after I got to work and everything I locked the doors and tried to unlock it the drivers door again and it wouldn't work but the passenger side did. Hopefully I'll have some time at work to take a look at it but if you guys have any idea of what it could be that would help a lot
Sorry for the long post and thanks in advance
Sent from AutoGuide.com App
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #2 of 13 Old 05-28-2013, 07:59 AM Thread Starter
Lunch time bump
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #3 of 13 Old 05-28-2013, 08:12 AM
MSTR-P's Avatar
Yeah...certainly wierd. Have you checked the accessory relay to make sure it is good? Are the other accessories working with the radio...like the windows? Might start there for troubleshooting.
'03 7.3 - Stock!
MSTR-P is offline
post #4 of 13 Old 05-28-2013, 08:25 AM Thread Starter
Well I just went out to start checking stuff out and everything worked. The radio turned on when the key was on and shut off when I turned the key to off. And the key fob worked both locking an unlocking. So now I'm confused with what's going on. I'll check the accessory relay when I get home. And to be honest I didn't think to check the windows and other accessories. I'll check that stuff as well and keep you posted
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #5 of 13 Old 05-29-2013, 03:53 AM Thread Starter
Well here's the update. Last night I went home and checked the fuss box under the steering wheel and the guy that owned the truck before me had the power for the snow plow controller on the radio fuse. The fuse was also ****eyed in there (wasn't making full contact) so I took the wire off and put the fuse back in so that it would go in all the way.
I'm thinking that that might had been the problem, but we'll see. If the problem happens again I'll know that it's something else
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #6 of 13 Old 05-30-2013, 02:28 PM
MSTR-P's Avatar
Would be nice if it was that easy. Good Luck!
'03 7.3 - Stock!
MSTR-P is offline
post #7 of 13 Old 06-13-2013, 12:02 AM Thread Starter
Okay guys I haven't had any problems til now. I just happen to wake up and look out the front window to see if there was any damage (big storm was supposed to come thru) and saw my dome lights were on. So I walked outside and saw the done lights and the lights on the 3rd brake light were both on. Radio wasn't on tho and the locks worked with the key fob. The only thing was that the lights were on. So I pulled the #5 fuse and put it back in, nothing. Pulled the #14 fuse and nothing. I even pulled the #14 and kept it out and shut the door and the lights stayed on. Could these problems have anything to do with a storm? Because both times now have been nights that it storms. Oh and I noticed that there was water on the floor mat? I didn't feel any water in the instrument fuse panel but it felt like it was coming from somewhere just to the right of the gas pedal where the floor is raised in the center. That may not make sense so I can get a picture if need be
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #8 of 13 Old 06-13-2013, 04:08 AM Thread Starter
What is wrong with my truck?! I went back to sleep and woke up for work this morning and went to start my truck and the dome lights were off. It started up fine and I finished getting ready then jumped in the truck. The passenger seat seatbelt light was on but nobody was sitting in the seat. I started driving and the speedometer was bouncing. It would get up to 50-60 then drop about 30mph and jump right back up to the speed so I turned around and went home and took my other vehicle to work
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #9 of 13 Old 06-13-2013, 04:19 AM
Colin7.3's Avatar
Honestly sounds like water is in something. Not sure what possibly the gem.
Water does not good things to electronics
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #10 of 13 Old 06-13-2013, 05:32 AM Thread Starter
Man I hope not, there could be a lot of damage if that's the case plus electrical problems dealing with water are hard to fix permanently, so I've heard
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
