All 4 brakes locked up!! Help!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-27-2013, 12:12 PM Thread Starter
atgreene's Avatar
99 f250 7.3 174k
When I was parking today my brake Pedal went hard and my brakes locked up. I really had to give it a lot of throttle to move. Parked it hoping it would be better when I returned. Same thing. Drove it home and all four corners were smokin hot and steaming. I also noticed it gets worse when I turn. If you drive, say one mile without braking, then the brakes gradually let off, but as soon as you hit the brakes again, same thing. They lock up. I've been reading that the power steering and brake system are connected via hydrobooster. About 4 months ago I topped off the PS system with PS fluid instead of ATF. Could this be causing my problem. I haven't had any problems prior to this, oh except when I make sharp turns I would notice the brake pedal become stiffer and the brakes we sticking.
What should I do?
Since its all four corners I'm leaning towards booster or master cylinder.
Should I do a PS system flush and put new ATF in?
Thanks!
atgreene is offline
post #2 of 4 Old 05-27-2013, 01:20 PM Thread Starter
atgreene's Avatar
i just went out to test the PS and it sucked. so say my PS pump is bad, would that cause all 4 of the brakes to lock up?
im puzzled on this one
atgreene is offline
post #3 of 4 Old 05-28-2013, 09:54 PM
Quoted: 722 Post(s)
Putting PS fluid in it killed your hydroboost seals and prolly you PS pump. That Sux. Hydroboosters are not cheap.
Corey@CNCFAB is offline
post #4 of 4 Old 05-29-2013, 06:47 PM Thread Starter
atgreene's Avatar
checked ps fluid and turns out it was just low, i did a flush with fresh atf and everythings back up and running. im lucky it didnt fry the pump. now just need to make sure there is no leak.
lesson learned: check fluids often & if all your brakes lock up, then check the ps fluid
atgreene is offline
