early 99 7.3 messin up - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-22-2013, 03:24 PM Thread Starter
mattmccutcheon's Avatar
about 3 weeks ago I noticed it starting to blow some white smoke at start up then it started to crank longer and today it dumped all my antifreeze and take a really long time to crank over if you have any suggestion to what this may be would be much appreciated thanks matt
e99
dp tuner
8in fab tech lift
mattmccutcheon is offline
post #2 of 5 Old 05-22-2013, 06:31 PM
preachermanhull's Avatar
Quoted: 2 Post(s)
what do ya mean by "dumped antifreeze"?
Psalm 34:6 "This poor man cried, and the Lord heard him, and saved him out of all his trouble."
94.5 psd, 310,000,
ts chip, homemade cai,
3in dp 5in exhaust, 265/75/16 tires,
glowshift gauges,
zf5, fpr shim, bench seat so my honey can get close! SOLD!
98.5 psd, 245,000, new a/t, banks gauges, 06 interior, 4 inch exhaust 5 inch tip, the truck is red
-Hosstyle Dieselz-
2004 F-250 6.0 4wd, auto...and get this, 356,000miles on og engine/trans! Stock for now...
preachermanhull is offline
post #3 of 5 Old 05-22-2013, 07:39 PM Thread Starter
Well it started gettin hot on me so I pulled over and it was all wet under the hood and so far I can't see anything wrong with the hoses
e99
dp tuner
8in fab tech lift
post #4 of 5 Old 05-22-2013, 07:53 PM
Quoted: 2 Post(s)
If i had to guess without seeing it...i would say headgaskets and/or injector cups.
94.5 psd, 310,000,
glowshift gauges,
-Hosstyle Dieselz-
post #5 of 5 Old 05-22-2013, 08:06 PM
Quoted: 2 Post(s)
you mentioned "hard to crank over"...if it is one of those two it could be getting water in the cylinders which would make it hard to turn over (like if the batterys were weak) I would'nt recommend trying to crank it if you think its getting water in the cylinder...if theres enough in there it can warp a rod if your not careful!
94.5 psd, 310,000,
glowshift gauges,
-Hosstyle Dieselz-
