Bad Cam Position Sensor? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-05-2008, 09:27 AM Thread Starter
bryceba's Avatar
I drove to work and parked my truck. When I went to leave it would just crank but not start. It would crank at normal speed for a few seconds and then it would act like the starter is bogging down. Its not the batteries losing power, I know that. Its like something else is making it slow down a little. Also there was some "smoke" coming out of the exhaust after I had tried starting it for a few times. Im not sure if it was actual smoke but it was greyish. So I towed it to the dealer. Does this sound like that sensor? Sorry if there has been alot of posts about this, I just had trouble finding one with the same situation. Thanks guys
2001 F250 CC SB
5 In exhaust made by me
DP-Tuner 80 tow, 80 econ, 140 aggressive SWEEETTT
Boost Controller
AFE Intake
Leveling Kit w/ 35x12x16
Projector Headlights
New MB Wheels
bryceba is offline
post #2 of 15 Old 03-05-2008, 09:44 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
Maybe glow plugs?
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #3 of 15 Old 03-05-2008, 10:08 AM Thread Starter
bryceba's Avatar
Anybody else have some opinions?
2001 F250 CC SB
Boost Controller
AFE Intake
New MB Wheels
bryceba is offline
post #4 of 15 Old 03-05-2008, 10:38 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
When cranking the truck, does the tach move or bounce any? If not the CPS is the problem. A lot of guys buy an extra 1 and keep it in the glovebox because it is a common problem with the 7.3. Hope this helps.
dhanna6powerstroke is offline
post #5 of 15 Old 03-05-2008, 10:52 AM
bigwhite6oh's Avatar
this probably isnt much help to you, but a work truck i was driving last fall with a 7.3 shut out on us while driving to a job and wouldnt start. after 45 mins of searching everything to the naked eye on the side of the road that couldve shut the truck down and not allow it to start with the road mechanic as well, there was a fuse under the hood (i want to say it was a 20amp fuse) that had blown. i wish i could remember what number/what it controlled...
2003 F350 6.0 PSD
\\CC//LB\\SRW//
Silverline Cat-Less Dual Turbo Back | Innovative Tuned X3
| S&B Intake | Autometer GS series Boost/Pyro gauges | Billet grille, IPCW ultra-clear clearance lights | LED bulbs for all | external lights | Recon White Lightning | LUND SunVisor | Fog Light Mod | High Idle Mod | Zoodad Mod | CCV Re-routed | Pioneer AVIC D3 | Alpine Type S/Rockford 3way speakers | Rockford 4 Channel Amp
bigwhite6oh is offline
post #6 of 15 Old 03-05-2008, 11:35 AM Thread Starter
bryceba's Avatar
The tach does bounce when its cranking, what does that mean? Also what was the "smoke" coming out of the exhaust and is that a really bad sign?
2001 F250 CC SB
Boost Controller
AFE Intake
New MB Wheels
bryceba is offline
post #7 of 15 Old 03-05-2008, 11:42 AM
Mod Newbie
Quoted: 20 Post(s)
Well, if the tach is bouncing the CPS is good. The smoke is just where it has injected fuel and is not firing. Nothing major. When you do get it started it will probably smoke quite a bit for a while but it won't hurt anything. I'll do some diggin and see if I can help on the no start.
post #8 of 15 Old 03-05-2008, 11:53 AM Thread Starter
bryceba's Avatar
ok tell me what you think of this. Yesterday I towed it down to the dealer and told them to replace the recall because thats what I though it was. I just got a call back saying, your truck is ready and we put a new glow plug relay in because the cps wasnt the problem. Your bill is 196 dollars. WTF!? I thought they had to call and get permission to work on a vehicle beyond what was discussed at first. I never said, Geti it running whatever you have to do. I said fix the recall. What should I do, is there anything I can do?
2001 F250 CC SB
Boost Controller
AFE Intake
New MB Wheels
bryceba is offline
post #9 of 15 Old 03-05-2008, 11:57 AM
Mod Newbie
Quoted: 20 Post(s)
I used to work at a dealership, and unless you signed something saying it was okay to repair, then yes they are suppose to get permission. What recall was it? They might have had to get it running for the recall to be performed. If not, go in and talk to the service manager and tell him you never gave them permission to repair the truck.
post #10 of 15 Old 03-05-2008, 12:02 PM Thread Starter
bryceba's Avatar
It was the cam shaft postion sensor recall that I thought was the problem. Thats what I said to fix. They said they put that part in and it still wouldnt start. I mean I dont know what to do. Should I call them and say take the part off because I didnt authorize that. I dont expect them to leave the part on and let me walk out the door free of charge because they didnt get my permission. So are my options basically these, take the part off and I will tow my truck home or pay for the service right? There isnt much I can do is there. I just dont want to get really heated and be a jerk all over some little part but I know I could buy a relay and replace the thing myself for half of that ya know? Any more advice you have?
2001 F250 CC SB
Boost Controller
AFE Intake
New MB Wheels
bryceba is offline
