2000 PSD Smokes/knocks at startup - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-17-2013, 06:16 PM Thread Starter
I've got. 2000 7.3 it smokes white/grey smoke at startup and knocks for about 2 seconds. Smoke will not clear until I jump on the throttle then she runs fine. The oils fine and there's no fuel in either the coolant or oil. Also throwin no codes. I'm about at white end with this thing. Can anyone give me some ensight on where to begin.
USMC250 is offline
post #2 of 15 Old 05-17-2013, 06:42 PM
05_PSD_Erik's Avatar
White smoke can indicate a cold engine with incomplete fuel burn. I would start by checking the health of the glow plug system....
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #3 of 15 Old 05-17-2013, 07:28 PM Thread Starter
Just checked the relay and its bad so I'm gunna replace it and see if that fixes the problem thanks
USMC250 is offline
post #4 of 15 Old 05-19-2013, 07:14 AM Thread Starter
I replaced the GPR yesterday it didn't do it after I started it up twice but then I proceeded to start acting up again could a GP be grounding/shorting out causing this problem. The GP dash indicator goes on and off as it should telling me the glowplug module/controller is working correctly.
USMC250 is offline
post #5 of 15 Old 05-26-2013, 03:47 PM Thread Starter
I replaced the glow plugs and relay yesterday it worked for the first 4-6 times it started no smoke or knocking. I don't know where to go next any help y'all can give me will be appreciated.
USMC250 is offline
post #6 of 15 Old 05-26-2013, 03:55 PM
jesilvas's Avatar
Quoted: 2 Post(s)
The WTS light doesn't mean anything. It means the PCM wants it to work, that's it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 15 Old 05-26-2013, 03:58 PM Thread Starter
So could that mean it can be the GP controller?
USMC250 is offline
post #8 of 15 Old 05-26-2013, 04:01 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What is the ambient temp during the smoke?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 15 Old 05-26-2013, 04:05 PM Thread Starter
It doesn't matter the temp hot or cool as well as the engine temp I can start it when the engine is at operating temp and it still does it.
USMC250 is offline
post #10 of 15 Old 05-26-2013, 04:09 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Definitely not GPs.
Possibly injection system issue or oil in the cylinders?
4R100, 2wd
330,000 + miles
jesilvas is offline
