Engine wont start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-03-2008, 11:07 AM Thread Starter
Engine wont start
For the second time in two weeks my '00 F250 wont start after a rainy day here in northern Mich. It turns over fine but I can hear a rapid clicking noise coming from behind the center of the dash. I dont hear this noise on normal start up. Any ideas what might be causing this?
John S.
john487 is offline
post #2 of 11 Old 03-03-2008, 11:27 AM
drstephennix's Avatar
Quoted: 3 Post(s)
Send a message via Yahoo to drstephennix
Isnt that what a dead battery sounds like?
2013 F350 Platinum LB 4x4
35" MT's
AFE Stage 2
74k miles
4" lift
In the words of David Crockett, "You may all go to hell. I will go to Texas!" spoken in the halls of congress; circa 1830's
drstephennix is offline
post #3 of 11 Old 03-03-2008, 12:07 PM
i would check both batts with a voltmeter if they are not strong enough the truck will not start,but it can still turn over also check codes they are the next place i would go if the batts are good
badazzstroker is offline
post #4 of 11 Old 03-03-2008, 12:35 PM Thread Starter
Had to leave the truck at work so I'll have to go back later. It did this same thing two weeks ago, but it started up fine after I left it alone for about 20 minutes. I drove it through some slush and big puddles to get to a job site just 2 hour prior to the no start. Could moisture be messing with something?
John S.
john487 is offline
post #5 of 11 Old 03-03-2008, 12:43 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Its possible the IDM or injector driver module is getting wet. Check all your electrical connections on the firewall as well
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #6 of 11 Old 03-04-2008, 04:35 AM Thread Starter
Well, it's morning now and the 12 deg. overnight temps with no place to plug the truck in have made it too difficult for the batterys to turn the engine over. I'm going to go out during my work break and change the fuel filter just to eliminate that as the problem. Then I'm going to try to jump strat it.
I had the IDM replace once already under warranty at about 30,000 mi. I've got 116,000 mi. now. The truck had the same strating problem back then. I need to find someone that can pull up my codes.
John S.
john487 is offline
post #7 of 11 Old 03-04-2008, 06:42 AM Thread Starter
Filter change dosent seem to have helped. I did find a little icy gunk on the lower side of the filter screen tho. Tried jumping it with a friends truck but the engine is so cold it's still having a hard time turning over. I'm still getting the rapid clicking noise in my dash too. I dont hear that noise on normal starts. Its not coming from my GPM, although my GPM does click when I turn on the ignition. I'll probably put in new batteries after work but I dont think thats my problem. Any ideas where I should start trouble shooting?
John S.
john487 is offline
post #8 of 11 Old 03-04-2008, 06:56 AM
Jmaccal's Avatar
CPS mine would do the same thing when wet. Check the recall for a new one.
Jmaccal is offline
post #9 of 11 Old 03-04-2008, 06:59 AM Thread Starter
Yeah, I havent had that replaced yet. Now I have to just get the truck there
John S.
john487 is offline
post #10 of 11 Old 03-04-2008, 07:47 AM
vitalidle's Avatar
Sounds like a voltage problem or dead batteries. You truck should turn over fine with good batteries. I have started no problems this winter in -3 temps without plugging in. Check your batteries and all connections.
Auto 93,000 miles
DP Tuner F5
