crank but no start. i got the cel codes help! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-12-2013, 03:57 AM Thread Starter
Hi I'm new to this forum and new to owning a diesel. I got a early 99 f250 with 124000 miles with a automatic. The problem I have is it will crank but not start without using ether I checked the fuses and hpop level and both checked good.
The codes it pulled were
P1280
P0198
P1690
P0381
P0603
P1212
Well the problem started 3 days ago I had drove 350 miles the day before. Well the next morning I go out start it and everything's fine. Well I go to a friends house and when I try to leave it just cranks so I pull the bully dog chip out and won't start still so I got ether and it started and ran fine but wouldent get out of park. Well I shut the truck off and checked all the fluids well it turns out to be a gallon low on oil so I fill it up and crank it with ether again after I got around the park safety lock thing oh and the abs light was on this whole time. After I drove for a while the abs light went away and the shifter started working but still need ether to crank. I drove 350 miles again and still same problems so I changed the fuel filter and still got problems. Any help is appreciated this it my only truck I have and I use it for work. My name is brad
997.3superduty is offline
post #2 of 3 Old 05-15-2013, 07:45 AM Thread Starter
Well turns out to be a bad ICP I took it out cleaned it and not it runs and starts fine
post #3 of 3 Old 05-22-2013, 09:08 AM Thread Starter
Never mind that lasted for 4 hours and same problems I changed the hpop, the caps and the IPR still same problems
