NEED HELP!!!!! - Ford Powerstroke Diesel Forum
Old 02-29-2008, 04:55 AM
NEED HELP!!!!!
i thought my wheel bearing assembly was going out so i took it off and replaced it. But i still have the same movement as before i replaced it. i check the ball joints they are also good. When the assembly is off there is a lot of movement at the end of axle before it goes to the knuckle could this be causing the problem?
Old 02-29-2008, 05:58 AM
the axle should have movement with the hub off...
the only two places that movement can really come from are the hub and ball joints...so check the ball joints again
Old 02-29-2008, 06:30 AM
KVFD
Man that sure is nice deer and all but you sure need to find a better huntin rig!!! the bow tie could chit out on ya i wuld be embarrassed to ride in a dam chevy
Old 02-29-2008, 06:49 AM
sorry man thats my dads truck i just feel like lifting the deer up into my truck haha
