Where's My OIL Going - Ford Powerstroke Diesel Forum
Old 02-28-2008, 01:31 PM
I have an early 99 thats using 2qts. of oil in 500 to 700 miles. There are no spots on the driveway nor do I notice any excessive smoke comeing from the tailpipe. I guess my question is can there be enough blowby to create my loss without causing alot of smoke? Also I am getting really bad mileage, right around 10mpg. But my truck is running fine. I am confused!!!
Old 02-28-2008, 01:52 PM
I would start by replacing the injector o rings if the engine compression is good....since its an early 99 with the old style o rings and your getting that poor of fuel economy its a good place to start!!!
Old 02-28-2008, 03:29 PM
Powerstroke Techie
Yep, if it aint going on the ground or into the coolant, which would eventually go on the ground, then it must be burning it and injector O-rings would be the most likely culprit. It aint as hard of a job as it sounds.
