Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 09-17-2006, 03:31 PM
73FD 73FD is offline
Ebpv
I just hooked my ebpv to be used as a brake and it worked fine for one day and now when i flip the switch it does nothing?!? I already checked to see if power was getting to the plug, check my inline fuse I put in, i also checked to see if the valve got stuck somehow so i manually moved the valve. is there anything else that could be wrong that I missed I dont know why it worked fine one day and not the next
in case you want to know how i hooked it up i pretty much used this setup
http://www.thedieselgarage.com/forum...ead.php?t=5894
thanks for any help
Old 09-17-2006, 03:48 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Welcome to the forum!
Marc or someone will be along to answer your question.
Old 09-17-2006, 07:39 PM
overl0rd overl0rd is offline
Send a message via ICQ to overl0rd Send a message via AIM to overl0rd
Do you have the motor running when you're trying to get it to work?
Old 09-18-2006, 07:04 AM
ya its running
Old 09-18-2006, 09:32 AM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
have you put a test light on the wire to make sure that power is getting there? got all your connections made very well??? Sounds like if it was working, now isn't, you have a bad connection
Old 09-18-2006, 01:50 PM
Fixed the problem, one the diode wires broke, must of bent a couple times to many. But thanks for all the quick replys and help I appreciate it. O yea another thing, good thing I did this mod because it made me notice the 2 top bolts on my turbo were missing I just got done puttin new ones in. that was a pain in the a$$, not easy to wrench anything back there.
Old 09-18-2006, 02:26 PM
Holy missing bolt batman! how did that happen?
Old 09-18-2006, 03:31 PM
guess they just wiggled out
