wheres my boost
I have a 2000 f250 7.3 whit a k&n cai a mbrp 4" turbo back exhaust a banks big head waste gate a boost fooler and i just put on a dp 6 position turner. My problem is i can on get about 20-21 lbs of boost. I had it pressure checked and it held air for 20 min and didnt leak any. I dont know if putting the stock waste gate on would help. Thanks
any help someone..
i have a set up close to this guys... Dp tuner.. Boost fooler and only get bout 20 21 psi... mines an 02 F350 |
Well
they run about 17 stock.
i have the banks waste gate too i don't know why it wouldn't be pushing more i have all the same as you ?????
First of all make sure your boost fooler is letting the map see enough boost, otherwise the fuel won't get called for, your map sensor might be going bad as well, unplug it and take it for a run and see what the boost is then.
Man so im not the only one, mine happened after i installed a new compressor housing, didnt leak beforehand but now it does, time to start looking this weekend
