Need alarm wiring help. wiring causing truck to go into limp mode. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-23-2013, 07:32 AM Thread Starter
My truck has been going in and out of trany limp mode. I have traced it to the wiring at the ignition harness under dash were the alarm hooks up. It is a bad connection of some sort. I am in need of the wiring color codes for that harness so I can try to figure out which one is causing the issue.
here is a picture of where im talking. this is not mine but wired at the same point. Its the white ignition harness plug.
2000 F350 2x4 superduty Dualy
5" drop
24" alcoaa rims w/ grappler uhp's
4" turbo back ex.
edge programmer
K&N intake with Napa 6637 filter
06' Grill, Mirriors, Led lights
444kyle is offline
post #2 of 4 Old 04-23-2013, 07:33 AM Thread Starter
trying to get a better idea of wich wire would cause the vss code to come up and make it go into trany limp mode. If I move the wires it will go in and out of limp.
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
post #3 of 4 Old 04-23-2013, 08:04 AM Thread Starter
here is a link I found but not able to figue out the wiring from it. Atleast not seeing one that would cause the vss signal to drop. Or maybe because mine is a viper with remote start its different in some way.
http://www.superdutypsd.com/alarm_with_remote_start.php
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
post #4 of 4 Old 04-24-2013, 06:44 AM Thread Starter
did find the post. the last post shows wiring color codes. But I was not able to locate the
Speed Sense Wire: Gray/Black (On diesel trucks go to the white/orange behind fuse box
ANY HELP PLEASE!
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
