01 turn signal issue - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-16-2013, 08:46 PM Thread Starter
when driving i turn my turn signal on and it works then i apply the break to slow down and it stops flashing and on the dash the arrow stops flashing and gets dim and is just lit up then when i let off the break it starts flashing like normal. this doesn't happen every time but it does a lot. does it when i turn right or left. the turn noise goes away also when i apply the break then when let off it starts up again. i have no clue what is causing it
travis182008 is offline
post #2 of 7 Old 04-17-2013, 12:47 PM Thread Starter
anyone ever heard of this problem,
post #3 of 7 Old 04-17-2013, 12:56 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Going out on a limb, but have you changed the flasher? Could it just be wearing out?
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 7 Old 04-24-2013, 06:34 AM
jpalma's Avatar
I am having the same issue right now. Mine is doing it every time though, I have done a little research and am thinking its a ground issue or with some of my trailer wiring. I only had 10 min to play with it last night and after fumbling with the wires for the trailer I got them to work with the brake on for a minute then they went back to being solid. Did you ever figure out the problem? Looking to fix mine asap as anything not working drives me crazy
2000 F250 Crew Cab, 366,500miles
,6637,Foil delete, Smoked Cab lights, Bed Liner Rockers, Muff. Delete,08 DIff Cover, 50 Gal Transfer Flow Tank
jpalma is offline
post #5 of 7 Old 04-24-2013, 06:35 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Multi function switch? AKA blinker switch?
2000-7.3L is offline
post #6 of 7 Old 04-24-2013, 08:00 AM
jpalma's Avatar
I don't think so? if that was at fault wouldn't my hazards stop flashing if the brake was depressed? Just went out and tried hazards on brake pressed still flashes as normal. I will have to dig into it tonight.
jpalma is offline
post #7 of 7 Old 04-24-2013, 11:42 AM Thread Starter
mine problem seems to come and go. it hasn't done it in a week but sometimes lasts a day or 2 then goes away. i have no clue whats causing this
