If I can't get this fixed im buying another chevy. - Ford Powerstroke Diesel Forum
post #1 of 32 Old 04-09-2013, 06:03 PM Thread Starter
now that I have your attention
After reading these forms for months, I decided it finally time to join and hope that somebody can please help me figure out whats wrong.
Truck: 1999 F350 7.3 power stroke, with the ZF6 and I think it's an April build date.
Problems: hard if not impossible start, smoking so bad it burns your eyes, and intermittent stalls from which it's won't always restart
New parts: Long block in 2004 by previous owner, 8 new injectors & glow plugs buy us ( ran AWESOME for about 3 weeks ) New turbo and pedestal, new ignition module( stopped the ignition for always being on), new cam position sensor, new glow plug relay and new valve cover gaskets.
What we know: cylinders 5 & 6 fail that balance/contribution test and it's not the injectors.
I know the ICP data is erratic, when it's unplugged we get the default value of 700psi but it still runs like crap.
EPB value seems suspect but I have no idea what a valid range of values are.
None of the IDM harness feeds appear to be grounded, and all of the switched grounds read open. the pin 26 ground had very high resistance, which we corrected and it still won't start.
After sitting all winter the truck refuses to start, we gave it some either and it popped but won't start, it sounds like it wants to start but it just won't catch.
Please help me figure this thing out. We are to far in to it to give up but we don't want to put in an HPOP or IDM to still have a crappy running truck .
BigLou80 is offline
post #2 of 32 Old 04-10-2013, 08:31 AM
timmyboy76's Avatar
best thing i can think of, is invest in an AE...
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 32 Old 04-10-2013, 04:24 PM Thread Starter
Im using a snap on scan tool. I am not sure why I would want another scan tool
Thanks though
BigLou80 is offline
post #4 of 32 Old 04-10-2013, 04:45 PM
Macon's Avatar
Without any solid ideas, what's the oil look like/ last time it had an oil change?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #5 of 32 Old 04-10-2013, 04:49 PM
Maybe bad fuel?
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #6 of 32 Old 04-10-2013, 04:51 PM
Is it smoking whle it's running or cranking? Bad up pipe leaks can do that.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #7 of 32 Old 04-10-2013, 04:57 PM Thread Starter
Oil is good,
After sitting all winter fuel may be questionable, but it had these problems when the fuel was fresh
It smokes so bad it leaves oily residue you can taste when or if you can get it running
BigLou80 is offline
post #8 of 32 Old 04-10-2013, 05:03 PM
Macon's Avatar
What color smoke?
Are you reading RPM's? Just because CPS is new, doesn't mean it's good.
How are the IPR numbers looking?
Have you verified oil level in HPOP before trying to start?
2002 F250 CCSB 4x4
Macon is offline
post #9 of 32 Old 04-10-2013, 05:13 PM Thread Starter
Originally Posted by Macon View Post
What color smoke?
Blackish, all 5 of us there agreed it's excess fuel
we were reading RPMs last fall, I think we also tried with the old CPS back in. when it was last running, i cound read the RPMS in the data stream I haven't tried while cranking
Last time it was running they looked OK not that I have a lot to compare them to. What are the expected range of values while cranking and running
We have not, it's on tomorrows to do list. Sad part is after the injectors the truck was running perfectly until something else let go.
BigLou80 is offline
post #10 of 32 Old 04-10-2013, 05:24 PM
Macon's Avatar
Assuming the injectors are all good since you've replaced them, it's possible turbo related. Not enough air for complete burn. Are you running any tunes by chance?
As part of your early checks tomorrow, remove the air filter and intake tube and check the turbo wheel. Make sure it spins freely and all that.
Since it won't start, see if you can read RPM's while cranking. If not, I would suspect CPS issue again. Get OEM unit.
I don't know while cranking, but my IPR runs at ~10% at idle.
2002 F250 CCSB 4x4
Macon is offline
