:please: explain p0471! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-08-2013, 05:52 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Feedback Score: 3 reviews
I can't find anything on what this code does...... I know what it is but what does it cause? Why is it being thrown?
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #2 of 12 Old 04-08-2013, 05:56 PM
Macon's Avatar
OBD2-OBDII Engine Light Trouble Code P0471 FORD - Exhaust Pressure Sensor Range/Performance | Engine-Codes.com
Possible causes
- Faulty Exhaust Back Pressure Sensor
- Exhaust Back Pressure Sensor harness is open or shorted
- Exhaust Back Pressure Sensor circuit poor electrical connection
Tech notes
Replacing the exhaust back pressure usually takes care of the problem
P0471 FORD Description
The Exhaust Back Pressure (EBP) sensor is a variable capacitance sensor that, when supplied with a 5-volt reference signal from the Engine Control Module (ECM), produces a linear analog voltage signal that indicates pressure.
The EBP sensor's primary function is to measure exhaust back pressure so that the ECM can control the exhaust back pressure regulator (EPR) when needed.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 12 Old 04-08-2013, 05:59 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Thanks! I did not know this sight existed.
Bully Dog intake
post #4 of 12 Old 04-08-2013, 05:59 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Would this code be causeing this?
I think i blew/ started to blow my turbo..school me. I think my turbo is on the fritz.... What do I look for? What are the symptoms?
When I go to accelerate I can mash the pedal to the floor and it takes 4-5 seconds before it will go. When it goes it goes, but it takes forever! At cruising speeds 45-70 in my area depending on the road, it jumps and bucks like crazy.
I'm hearing a slightly different whistle from it than normal.
Also, when I shut the truck of, there is a horrible knocking/grinding noise real quick like, like a fast 3 count.
I have really bad compressor surge too.... A wicked wheel is on its way....
Bully Dog intake
post #5 of 12 Old 04-08-2013, 06:26 PM
350 ONE TON's Avatar
Possible causes
Tech notes
Where is the EPR and what does it look like? Never knew these trucks had such a thing
2003 F250 XLT 6Spd 4X4 ECLB 4" lift 4" turbo back duals, AFE Stage 2 XP, superchips flashpaq (gone soon I hope) GTP38R, Gutted EBPV
350 ONE TON is offline
post #6 of 12 Old 04-08-2013, 06:57 PM
right side of the hpop reservoir. 99 and newer on the back. 97 front
10redly is offline
post #7 of 12 Old 04-09-2013, 05:28 AM
Interesting. Now I gotta go look lol. Learn something everyday. How does the truck control EBP? With the waste gate? That's about the only way I can figure since these aren't VGT turbos
post #8 of 12 Old 04-09-2013, 05:37 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
I'm still kinda confused.... I had my valve at the turbo unplugged.... Maybe its stuck or something an causing my performance issues? I plugged it in last night. I'm riding with dad today so I haven't had a chance to test....
Bully Dog intake
post #9 of 12 Old 04-09-2013, 05:57 AM
Is it hissing like the ebpv is on?
post #10 of 12 Old 04-09-2013, 06:13 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Naw not hissing....
Bully Dog intake
