sloppy steering after new parts, what next? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-06-2013, 10:03 AM Thread Starter
Hey. Its a 99 f350. I replaced the steering gear box and drag link already. The tie rod ends seem tight. But when I have some one turn the wheel it appears the steering shaft is tight going up to the wheel but the pitman arm has a delay before it starts to turn. do I have a bad gear box or could it be the pump is shot and not producing enough pressure.
Thanks
early 99 F-350 cc, lb, 4x4
tony wildmann 6 pos.
4 in turbo back to a pair of 6" black chrome miter cuts
foil delete, stage 3 cold air intake
6 in lift with 37"s
238/100 sticks
not much but its a start
gibbogr is offline
post #2 of 4 Old 04-07-2013, 08:52 PM
If the steering shaft is turning and the pitman arm is not, then the problem can only be in the steering box.
Greenman01 is offline
post #3 of 4 Old 04-07-2013, 09:39 PM
Macon's Avatar
x2. If you're seeing the box making effort, but the pitman arm is not, it's the box.
Now, if you're *hearing* the box work, but not seeing anything, it could be the box, and/or fluid levels. I would assume that you checked levels before asking us though.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 4 Old 04-08-2013, 10:43 AM Thread Starter
Do u guys think its worth trying to tighten up the box with the allen screw on top or just return it n try a new box. The box was baught last fall.
6 in lift with 37"s
238/100 sticks
gibbogr is offline
