Help! P1211 Code - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-04-2013, 08:59 AM Thread Starter
Help! P1211 Code
I have a 1999 F250 7.3 with 127,000 miles. It's used as my work truck and I had to get on it the other day and a "service engine" light came on. Read the code and P1211 popped up. "Injection Control Pressure (ICP) Not Controllable-Pressure Above/Below Desired". I don't feel like it's running any differently but I have only owned it for about 3 weeks so I don't know the truck that well. Thank you!
argrafton is offline
post #2 of 5 Old 04-04-2013, 12:13 PM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
if it aint running bad it is prob just the icp sensor not the icp itself, any parts store should have one. is ok to run with it unless you have emissions/inspections
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 5 Old 04-04-2013, 12:20 PM
Macon's Avatar
I would alter that to read: it's okay to run it until you get a new sensor. Any sensor that throws codes means it feeds the ECM info it needs to run right. A faulty sensor may not hamper operation short term, but can lead to inefficient operation down the road.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 5 Old 04-04-2013, 12:26 PM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
correct, the pcm puts in a default value for it and keeps reading other sensors to make up for it...If a person HAD to it could be run like that for a good long while, good for it? no but not going to hurt it...
dannanw is offline
post #5 of 5 Old 04-04-2013, 12:32 PM
Macon's Avatar
That's all I'm saying. You can run your truck without an air filter, just so long as you're on the way to get a new one.
2002 F250 CCSB 4x4
Macon is offline
