diesel on southbend dual disk - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-29-2013, 04:25 PM Thread Starter
WVRigrat05's Avatar
My buddy popped the seal on his fuel filter on the way home today. So needless to say it covered the clutch. This happened once before and ruined the factory clutch. Will diesel hurt this southbend? He power braked it and the truck stalled so its not slipping yet
Reger
Black 05' Silverado 2500 HD 4X4 CC/SB, LLY, LT3
Built motor and Trans by Blackout Performance
PPE stage v Trans, Suncoast 1057, 20 over sticks, pile of stuff to take it. EFI Live w/ DSP5- Gone
08' GMC SLT- EFI some other stuff
2011 Puma 30' KDBSS
WVRigrat05 is offline
post #2 of 3 Old 03-29-2013, 05:21 PM
Macon's Avatar
fuel oil getting on any clutch is bad. If he is overly concerned about it, he can pull the clutch, clean it with some acetone and a green scotch pad and put it back in. If it was mine and I burned up one clutch with the same malfunction, I would go through the effort if the clutch was fairly new. Then I would replace the fuel filter assembly since it seems to have a recurring problem.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 3 Old 12-29-2013, 09:29 AM Thread Starter
WVRigrat05's Avatar
Forgot to post a long time ago but, the south bend was fine, still running it, and no more o-ring failures.
Reger
2011 Puma 30' KDBSS
