cold start issues - Ford Powerstroke Diesel Forum
Old 01-26-2008, 01:22 PM
cold start issues
Ok, I changed both batteries because they were going below 11 volts on start up (9.8 volts). Now when the truck starts it fluctuates between about 400 rpm and about 1000 rpm for about 30 seconds. It's like it's trying to catch but can't. It takes about 2-3 seconds to go from 400rpm to 1000 rpm and back to 400 rpm. after this, the truck runs fine. Any one got any ideas?
Could it be an Oil issue? I'm running 15W30 and its getting down to about 10 to 15 degrees F at night.
Old 01-26-2008, 01:38 PM
How cold, do you plug it in?
Old 01-26-2008, 02:36 PM
I usualy keep it in a heated barn or plog it in around 25 deg, but I have been leaving it out side because next weekend I am going to the U.P. Michigan snowmobiling and the truck will be sitting for 5 days without power. I want to make sure that it starts when I return.
Old 01-26-2008, 07:46 PM
Send a message via Yahoo to tocools
You mite want to check your glow plugs out
They may be getting weak
