Guys, my truck has started "wobbling" bad when coming to a quick stop or if I hit big bumps(im from minnesota, so our roads are nothing but potholes this time of year). Is this the notorious "death wobble"? If so, how does a guy silve it? I read on a few other forums that it's as simple as replacing the track bar? My wife and kids ride in there pretty often and I need to fix this as soon as I can. Thanks for any advice!
I forgot to mention this wobble is in the front end. The steering wheel goes nuts when it happens and takes just about all you got to keep the sonofab**** on the road when it happens at 55+mph!
Check all your joints in the steering system from the steering box down to the tie rod ends for any excessive play. that is the #1 reason for it to start happening. Also check ball joints and axle bearings for wear and replace anything that has any slop in it.
And once all your parts are good, it will help to add a dual steering stabilizer kit to your truck. This will help your steering components last longer and avoid the Death Wobble!!!
I have checked most of the steering components, and there is little play, but nothing terrible. All I can think of is the T bar... if its not that, what are the top secondary reasons? I cant afford to rebuild the whole front end right now, so I have to pinpoint the top possibilities and go from there...
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
