I have a ts 6 position chip installed on my 02 7.3 and seems to having an issue.... It supposed to be stock high idle 50 75 100 110 tunes or something really close to that anyway it seems that the first 4 spots are high idle and only one hp tune and it's not that much any ideas why it's not working properly FYI I've scrubbed the terminals very well
I made a dumb mistake and disnt realize there were two sides the first time I scrubbed it and it didn't work at all then I just scrubbed it a little bit on the bottom side and put it in maybe the one side isn't scrubbed good enough or the chip was flashes wrong from xdp idk I'm goin to call them and see what they say
Grab a q-tip and some acetone.
you'll need to clean all that silicone off the terminals. Otherwise - use a red/green scotch brite pad, or even some 120 or 180 sand paper.
Just be very carful. Once the silicone is off, and you just barely start to see copper under the tin - stop! You're right at the point you need to be for the connections.
Clean off the terminals with a little rubbing alcohol and put it all back together again.
I have my Ts Chip on now - and that's what I did, works like a champ.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
