Twice now the nut has popped off in 2 days. Noticed it first when i was checking valley oil leak (again) Then again when truck died taking a right turn into work.
Im assuming there is a reason the nut is from stamped sheet metal. Maybe it is suppose to pop off when the IPR is failing?
If so could this be the reason my HPOP seal is leaking again in less than 9 months?
