Help, Truck runs like it used to with map unplugged. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-17-2013, 03:33 PM Thread Starter
cv0lv0g0's Avatar
I have inherited my fathers truck and have been fixing a lot of things on it. Now, this is where I'm confused I knew the truck's map sensor had been unplugged for awhile now it doesn't go into limp mode nor does it roll smoke. But it does go limp with it plugged in. I know the map is bad however what doesn't it go limp without it?
cv0lv0g0 is offline
post #2 of 6 Old 03-17-2013, 05:38 PM Thread Starter
cv0lv0g0's Avatar
I just went out and Messed with the truck a bit. With the map sensor plugged in I tried line locking it and let the turbo spool up it wont go over 2000rpm with it unplugged it will reach about 3200 this was warm but not operating temp.
cv0lv0g0 is offline
post #3 of 6 Old 03-17-2013, 05:43 PM
BSkopnik's Avatar
If its unplugged, doesn't it just use a default value similarity like if you unplug the icp?
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
post #4 of 6 Old 03-17-2013, 06:15 PM Thread Starter
cv0lv0g0's Avatar
I was just a bit fuzzy, due to the different posts about unplugging it an black smoke rolling and I was curious to why mine wasn't if it was unplugged.
cv0lv0g0 is offline
post #5 of 6 Old 03-18-2013, 08:43 AM Thread Starter
cv0lv0g0's Avatar
So should I replace it or just leave it as is.
cv0lv0g0 is offline
post #6 of 6 Old 03-21-2013, 02:04 PM
Seth14's Avatar
It's probably bad, i paid 105 for mine from advanced. And i think it does go to a factory seeing in the ecm if it's unplugged
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
