need code info - Ford Powerstroke Diesel Forum
Old 01-18-2008, 07:18 AM
need code info
I'm new to this site. I own a 2002 F350 Dually Auto with OverDrive. I am having tranny problems. My OD light flashes, the tranny shifts at high RPMs. I have to let off the gas a little for it to shift sometimes. Also when I put it in reverse it has a delay before it kicks in. I have it at a dealer and the codes they pulled were PO605 I was told this code was due to the Bully Dog chip that I have Installed in the truck and then the rest are PO741, PO733, PO782. I was just wondering if I would be lucky enough to just have solenoid problems like the other guys on this forum or do I need a new tranny for $2,500. Thank You I would appreciate any info
Old 01-18-2008, 07:24 AM
Desert Shield/Storm Vet
Here are your codes:
P0605 Internal Control Module ROM Error
P0733 Gear Three Ratio Error
P0741 Torque Converter Clutch Circuit Performance/Stuck Off
P0782 2-3 Shift Error
I can't help you, but usually I see the P0603 code for programmers or chips, so not sure on the 605.
Old 01-19-2008, 03:50 AM
Powerstroke Junkie
The 605 shouldn't be caused from the chip. I would call John Woods and ask him, but it sounds to me like a new trans is in your future.
NCH
Old 01-23-2008, 04:07 AM
Thank you guys for your help. I really appreciate it
