My 1 Million Dollar ? - Ford Powerstroke Diesel Forum
Old 01-17-2008, 03:38 PM
The other day I was driving my 99 F350 SD (7.3L of course) and it was low on fuel. I took it up a hill and it stalled. I shut it off and put some fuel in the tank and turned it on again. It started but stalled shortly their after. I havent been able to get it started since. Today I took the fuel line off the outtake of the pump and the pump is definitely pushing fuel. However, when I observe the fuel filter housing it appears that no fuel is coming in from the pump or out to the cylinders. I am struggling with what to do/check from here. The fuel filter is not gunked up at all so I dont think that there was a bunch of sediment pushed up that far. Could it be clogged below that? How should I go about fixing that? How would I get air bubbles out of that line? Any help would be greatly appreciated.
Old 01-17-2008, 04:14 PM
Put it back together and cycle the key several times, should start and run.
If it doesnt may have just been a coincidence that it was low on fuel, and the infamous cps is out.
Old 01-17-2008, 04:21 PM
Send a message via AIM to strokin' fool
I just basically had the same thing happen with mine. I have a 1999 F250 and it was low on fuel and started acting funny. I put fuel in it and the water in fuel light came on. I was able to drive it for about 18 miles to a friends house and then it died there. I had low fuel pressure (10 pounds) after the pump and air bubbles in the line. I changed the fuel filter, fuel pump, dropped the tank and cleaned it out, checked the HPOP for oil, checked all fuses and no luck at all. I am confused. I dont know where to look next. Wish I could help. Good Luck!!
Old 01-17-2008, 04:27 PM
KVFD
its cheaper to keep fuel in the tank!
Old 01-17-2008, 04:39 PM
The dealer changed my cps back in december because of the recall. Do you still think that is a possibility?
Old 01-17-2008, 04:40 PM
KVFD
does ur tach move when u crank it???
Old 01-17-2008, 04:42 PM
No, the new part # seems to fix the cps, sounds like you need to bleed the fuel lines.
Old 01-17-2008, 04:47 PM
These trucks should not need to be bled. They bleed themselves if you cycle the key a few times.
Old 01-17-2008, 04:50 PM
Almostdunfukinwidit
How much fuel did you put in? You need to put in at least 10 gallons and run it to get the air out of the system.
Old 01-17-2008, 04:55 PM
It only has about 5 gallons of fuel in it, but like I said the pump is definitely pushing fuel... what would the purpose of more fuel be? pressure head?
