Help! Weird noise on left side of truck! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-16-2008, 12:29 PM Thread Starter
dieselpower88's Avatar
Send a message via AIM to dieselpower88
Hey guys
I have a 2000 F-250 and i have a weird sound coming from the front left wheel area. My break pads were just replaced and now i have a problem. the breaks work great but the sound im hearin almost sounds like axle problems. It seems every rotation of the tire it makes a rubbin sound. i can feel it on the floor board of the truck. anyone in the passenger can feel it to. i think its vibrating across the truck. i saw that my ceals on the axle are really loose but i think its been like that for a while. i just recently replaced the torque converter 1200 miles ago. i still havent replaced the tranny fluid(which needs to be done) and i changed the front and back differential fluid yesterday. my dad replaced my break pads on the front left, where i think the problem is, and he says check the clip on the pads....? i am not for sure if thats the problem but if anyone could give me any ideas what it could be, it would be greatly appreciated. if i cant fix it or its too expensive, i might have to sell it and i deffinately dont want to do that. thanks guys
Austyn
dieselpower88 is offline
post #2 of 7 Old 01-16-2008, 03:47 PM
jcs
jcs's Avatar
not sure what it is but here's a for ya
early 99 7.3 supercab xlt s/b auto 4x4
08 Tailgate
Isspro gauges (boost,pyro,trans temp)
Ford AIS
jcs is offline
post #3 of 7 Old 01-16-2008, 04:11 PM
460+'s Avatar
Take the wheel off and turn the rotor by hand and see if it sounds like the rotor is rubbing the backing plate.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #4 of 7 Old 01-17-2008, 12:01 PM Thread Starter
well i took the tire off, but it sounded almost like it was rubbin on the brand new break pads that were put on. the rotor also looks a lil warped when i spin it. but i dont think that a warped rotor would make that sound. im no expert tho. thanks
post #5 of 7 Old 01-17-2008, 12:39 PM
silverF250's Avatar
Check your wheel bearings.
Pat
2000 F250 Carpenter's Union local 2214
LOOKING FOR SIDE JOBS
Mac intake,5" exhaust with6" tip,Zoodad,foil delete, ts chip, WW
96 E350 bad trans mod NO MORE.
silverF250 is offline
post #6 of 7 Old 01-17-2008, 12:51 PM
willholl79's Avatar
Sounds like wheel bearings to me. Mine sounded like that and it was the wheel bearings. I replaced them (pass side) immediately and three weeks later the pass side wheel locked up with no warning. Manufacturer(bearing assembly) gave me a new one. Still didn't cover the tow bill though.
2005 F-350 CC LB 4x4 XL 6.0
SCT
4" Turbo back exhaust
03 turbo
Studs
Coolant Filter
Warren Stock+ injectors
1996 F-250 ECLB 4x4 XLT 7.3 Auto
1993 F350 CCLB 4x4 5spd 7.3 NA
willholl79 is offline
post #7 of 7 Old 01-17-2008, 12:58 PM
GoldieStroker944's Avatar
make sure that the rods that the pads slid on are cleaned and greased cause i have found on super duty breaks if those arent free it can screw up alot of stuff and make all kindas of noises
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
