Help!
Today I put in my Bully Dog 6 pos. chip and I changed the fuel filter on my 99 F350 Super Duty w/ 7.3L PSD. When I got it to start (cold weather w/o a place to plug in) it seemed to start up fine, but it sounded like one of its strokes was going to throw a cylinder into the cab. It calmed down quickly and reached a normal idle. I didnt think anything about it at the time. I took it out for a spin to put it through the new tunes. After driving it for a few minutes the battery light came on (its been doing that every now and again on longer trips, but goes off so I havent really worried about it... wrong answer I know). I didnt think too much about that either and proceeded to drive it around a bit. It was a little low on fuel and as I went up a hill it seemed to begin stalling out so I slowed down and took it out of the power settings on the chip. When I got back on the gas the RPMs would climb but the truck would barely move. I got out and put some more fuel in it and tried to start it up again. It started but the same inability to move continued and it stalled out. I tried to start the truck up again and it went all the way to the point it should turn over and run on its own and it made a loud knocking noise and kept doing that. From there I removed the chip and tried to start the truck again and got the exact same results. Here are the possibilities I can think of:
1. It ran out of fuel and now needs to be primed
2. Something is wrong with the alternator
3. Something else entirely went wrong
*Note: I did not go crazy on the truck with the new chip. I eased onto the accelerator and didnt see the rpms go above 3,000
If you know anything about what could have gone wrong please respond with possible solutions. I'd love to fix it in place and get it moved ASAP, but realize that may not be possible at all.
