CHECK ENGINE LIGHT - Ford Powerstroke Diesel Forum
Old 01-15-2008, 03:20 PM
Send a message via Yahoo to drtydzel
CHECK ENGINE LIGHT
HEY ALL I JUST INSTALLED A THE PARTS LISTED IN MY SIGNATURE BLOCK AND WHEN MY TRUCK HITS JUST OVER 22PSI BOOST I KICK A CHECK ENGINE LIGHT I HAVE THE DUAL BOOST FOOLER AND THE DFUSER ELECTRONIC BOOST FOOLER WHY AM I KICKING BOOST CODES SOME HELP PLEASE
Old 01-15-2008, 03:23 PM
have you pulled the code?? Could be a P1211 which is set running a hot tune when your HPOP cant keep up and is actually normal for these trucks on a stock HPOP
Old 01-15-2008, 03:26 PM
i prefer the itp overboost kit myself
Old 01-15-2008, 03:35 PM
WELL ILL TRY TO PULL THE CODE TO BE SURE WHAT IT IS HEY WHY DO YOU PREFER THE ITP OVERBOOST ANNILATOR LET ME KNOW YOUR REASONING AND MAYBE ILL HAVE TO SWITCH UP SOME PARTS THANKS IF ANYONE ELSE KNOWS ANYTHING IM NEW TO THE GAME AND TAKING ALL ADVICE
Old 01-15-2008, 04:05 PM
goes in line and regulates what boost the map sees without blowing it off as others do which loses boost psi and you can set it to what ever pressure you want
