Will Not Take Fuel - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-15-2008, 02:26 AM Thread Starter
Will Not Take Fuel
03 E350, will not take any fuel, takes 10 minutes to put 3 gallon in. Has to be half empty before I can fuel and top off, I would think it is something simple by not being a mechanic I am completely stumped. Tell me what I can look for and what I can do. Thanks
6foot9 is offline
post #2 of 3 Old 01-15-2008, 02:47 AM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
the only thing I can think of is maybe the air passage is blocked.Corect me if i'm wrong but I think the pumps shut off by air pressure. You can also try putting the nozzle at a different angle or not in as far. hope you get it figured out good luck
pinkfloyd is offline
post #3 of 3 Old 01-15-2008, 02:52 AM
dgw65's Avatar
check the vent hose attached to the filler neck and the filler hose. if either are kinked or plugged it will cause that problem.
dgw65 is offline
