cranks but wont start
starter was bad so i replaced it drive it home shut it off wont start back.replaced cam sensor and and glow plug ciel.. still nothing .need help thanks
Check your battery voltage. If it is 11.5volts or less you may need to try and charge them. If the pcm does not read at least 11.5 volts from the batteries it will not work. Also check the connections at the starter. Just to make sure they are good and tight.
Check and clean your battery terminals. Dirty or loose connections will cause a drop of voltage and amperage which may cause a crank no start situation. Last but not least, Welcome to the Org. |
