Glow Plug solenoid
The glow plug solenoid wont shut off after ignition is turned off and the wire that feeds the solenoid shuts off. but the power continues to flow through the solenoid? 2000 f350 7.3 Powerstroke. Bought rebuilt motor put in and wont start?
what "post' you checking, for power?
the Post that goes to the glow plugs
think your wiring is messed up...what color wires you got at relay and i'll go check my truck.
I'd post wire orientation, but my g.p.r. went out, so now ALL my wires are on AIH relay.. |
GPR wiring
Remember, the solenoid is just a "Remote Switch". Sound like yous is just bad, with the contacts welded together...
if the vehilce is plugged in will the glow plugs still glow or is the motor warm enough that it doesnt need them? 65 outside.
I replaced the glow plug relay and know its just cranking and still not firing. relay seem to be work correctly small wires turn on and off with key doesnt energize connector out to glow plugs vehicle is plugged in block is warm is this why it doesnt enerigzer connector to glow plugs
starting a 7.3
is wd-40 in the air intake a good idea to prime it?
nothing in the intake is good, except air.
