low compression - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-14-2008, 02:32 PM Thread Starter
low compression
Any thoughts on minimum compession preasures fo a early 99 7.3?
Thanks
blue62 is offline
post #2 of 4 Old 01-14-2008, 02:36 PM
Desert Shield/Storm Vet
vitalidle's Avatar
They should be around 400 psi, but what your are looking for is any major difference from cylinder to cylinder.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 4 Old 01-14-2008, 03:32 PM Thread Starter
Thanks, That's what I thought, this heap has a bunch of problems, but the big two are hard to start cold and loses power and white smoke after half throttle, checked glow plug system, ok, fuel preasure and hp oil ok, injector buzz test ok but some of the injectors sound slightly muted, checked compression 350-375 psi across the board, wanted to rule out tired iron, turbo fins looked good, starting to suspect injector problems.
Any ideas are appreciated,
Thanks
blue62 is offline
post #4 of 4 Old 01-14-2008, 06:09 PM
mako314's Avatar
have a cylinder contribution test run it'll catch problems that a buzz test will not
just call me Ashley!
2000 F-250 SC Lariat Destroked CR 5.9 Cummins 1-14-09
2006 F350 CC 6.0 4" exaust, DP tuned and to chicken to go any further
2004 Explorer V8 limited "all black"
1990 7-UP mustang 5.0 LX 25th annivesary
mako314 is offline
