2000 no start.
Ok, new poster here but i need help.
I have a 2000 F250, auto, 2WD and I can't get it to start. It turns over, will knock for a second or two and die. Puffs Black smoke when it does so. I get good Oil pressure and the Tack does jump some. I just changed the ICM on it and the number 2 injector. I have checked my fuses, HPOP oil level and changed the fuel filter. If anyone has any ideas it would be much appreciated. Also had the recall on the cam sensor done a little while back. edit, it ran after i did the number 2 injector change....just ran like crap. Now i cant get it to start at all. |
You might have not hooked up the under valve cover harness on that side good enough, or maybe just need to crank out the air in the oil rail.
