%&@*#$(%&@*# OIL LEAKS!!!!!
I am about ready to take a match to my freaking truck. This is the 4th oil leak in the same damn spot!
is there anyone else out there that has had problems with the fittings on the stealth system. it is always the same fitting where the 2nd line comes out of the front pump. I've replaced the elbow, oring, and threaded fitting 3 times now and guess what. the @&#*$*$&#@ thing is leaking again!!!! anyone want to buy a 2000 7.3???? |
hmmm
i'll sell you some jb weld.
i dont know what the stealth system is? what does it do????
stealth = dual hpop (high pressure oil pump) system.
Your oil leaks.....my fuel leaks. I feel your pain bruther I feel your pain.
Craig |
Gotcha Ya! sounds like a pain in the azz!!
haha, how much?
![]() or, before ya take the match to it, just send me the stealth system and any other worthwhile mod *cough* turbo *cough* |
On the JIC fittings make sure the tip is not dented. It has to be flat. you can clean up the tip with some sand paper or a file. Just a thought
You better fix your truck and bring it up to the spring gtg. I need some more 7.3's to run against! :fawkdance:
![]() Quote:
