No crank, no start... HELP - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-05-2013, 07:06 PM Thread Starter
I truck was running fine, turned it off went into the restaurant to go eat. Came back out and no crank no start, tried jumping both batteries and still nothing. I hear the fuel pump come on but no crank.. . help!! Please call 9188517646. In Virginia beach
shanerbanner10 is offline
post #2 of 10 Old 03-05-2013, 07:36 PM
Powerstroke Techie
Quoted: 315 Post(s)
check your battery terminals first. if they are clean and tight, disconnect the starter signal wire and jump it to the positive battery terminal. it's a single wire connector at the passenger side rear of the engine bay. right near the vacuum pump. if it still doesn't crank, you will need to do a bypass jump. jump the starter signal wire (small wire) at the starter to the starter motor cable (big wire).
if it still doesn't crank, either the starter is bad, engine to chassis/chassis to battery ground is bad/has a bad connection, or the B+ cable is bad/has a bad connection.
the richest ones are not those who have the most, but those who need the least
kaya is offline
post #3 of 10 Old 03-05-2013, 08:14 PM Thread Starter
Thanks for the reply, I got a tow truck headed this way. Going to try and take a look tomorrow.
post #4 of 10 Old 03-06-2013, 06:25 AM
timmyboy76's Avatar
unplug the fuel bowl heater, check the blown #30 30amp fuse...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 10 Old 03-06-2013, 06:53 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
But it doesn't even turn over on the starter - right?
First thing I would do is to Lift Up on the Shifter, a little past Park (and maybe try N)
Sounds like a typical out-of-range NSSW because of slop in the shifter tube or connection to the cable at the bottom...
NoRalPh is offline
post #6 of 10 Old 03-06-2013, 03:24 PM
rmb1393's Avatar
I have the same problem....drove it back from class today, it sat in the driveway for three hours and when i turned the key nothing. The slight single click and nothing after that. I checked battery connections and it was fine and i replaced them both a year ago along with the starer...i have no idea why it won't even crank. PLease help!!
2002 Ford F-350 7.3L
Regular cab
8 ft. bed 4x4
Isspro EV gauges (pyro, trans temp, boost)
6637 Intake with Donaldson B085011
Ts 6 position performance chip
4" downpipe to a side pipe with 5" tip
rmb1393 is offline
post #7 of 10 Old 03-06-2013, 05:02 PM Thread Starter
Bypass worked, changed the starter relay. It cranked right up 3 times and then the same symptoms came back. However bypass jump still worked. After I got it running again I shut it down waited a moment and it cranked back up... Any idea?
post #8 of 10 Old 03-06-2013, 09:52 PM
Powerstroke Techie
Quoted: 315 Post(s)
why did you replace the relay? you're going to need a starter circuit diagram to continue testing.
kaya is offline
post #9 of 10 Old 03-07-2013, 07:37 AM
check your wiring going to the middle post of the relay
MIDWBOSS is offline
post #10 of 10 Old 03-07-2013, 08:15 AM
i had the exact same problems and this^^ is what caused it
_________________________________________
02 f350, AFE stage 2 intake, wicked wheel, edge
evolution, performance authority trans, 10" lift 38's
with 4:56's, C2 gauges, 4" turbo back AERO muffler
TD444EVER is offline
