No crank no start after driving to eat. Was running fine - Ford Powerstroke Diesel Forum
Old 03-05-2013, 06:06 PM
I truck was running fine, turned it off went into the restaurant to go eat. Came back out and no crank no start, tried jumping both batteries and still nothing. I hear the fuel pump come on but no crank.. . help!! Please call 9188517646. In Virginia beach
Old 03-06-2013, 11:48 AM
take a screwdriver or wire and try jumping the two big post on the relay on the fender passenger side under the hood. if you jump that and it cranks check the 15 amp fuse under the dash in spot 20. it will be in the middle row second one up from the bottom
Old 03-06-2013, 03:59 PM
Bypass worked, changed the starter relay. It cranked right up 3 times and then the same symptoms came back. However bypass jump still worked. After I got it running again I shut it down waited a moment and it cranked back up... Any idea?
