Really hot engine!! Coolant temp good!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-04-2013, 09:01 PM Thread Starter
I seem to have an issue.. My engine is really hot. It doesn't overheat or anything. I went for a 20 min drive with it and came back I popped the hood and and I noticed a lot of heat. If I touch the turbo you will burn your hand. Same underneath I just touched the oil pan got a nice burn from it. Oil filter is pretty hot as well. Running 15w40. Anyone know if this is normal ? Driving for half an hour you should be able to touch the turbo and be relativity cool no? Same with the oil pan? Does everyone's 7.3 do this? Does the oil always get this hot in 7.3?
Mrgoodstuffdan is offline
post #2 of 13 Old 03-04-2013, 09:05 PM
aussie=effie
bob harris's Avatar
hot engine
thermostat stuck closed maybe
bob harris is offline
post #3 of 13 Old 03-04-2013, 09:06 PM
Macon's Avatar
Get some gauges. At cruise, your EGT is well over 400*, that goes right into your turbo. Engine oil will be in the 180* area. I can't tell you if what you're experiencing is normal or not, as you have no numbers. If it's not over heating, I'd say it's running right.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 13 Old 03-04-2013, 09:17 PM
ZMANN's Avatar
Quoted: 1355 Post(s)
oil temps can get to 180 or more so thats a no touch zone also
EDIT LOL I see that tidbit was mentioned
We Miss you Ronnie
ZMANN is online now
post #5 of 13 Old 03-04-2013, 09:22 PM Thread Starter
It a little odd to me that a turbo would get that hot after 20 min drive ? I didn't even kick the turbo in. I couldn't imagine what it be like towing and driving it for 4 hours
post #6 of 13 Old 03-04-2013, 09:27 PM
Macon's Avatar
Whether you're creating a lot of boost or not, the turbo is spinning. The spinning generates little heat though, because of the constant oil flow over the bearings. However, exhaust gasses are always going through it. That transfers a lot of heat.
2002 F250 CCSB 4x4
Macon is offline
post #7 of 13 Old 03-04-2013, 09:31 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
The turbo will get hot to the touch at idle.
dhanna6powerstroke is offline
post #8 of 13 Old 03-04-2013, 09:49 PM Thread Starter
I just had the engine out if it to change the oilpan. I changed the pan and I figured I go underneath to see if any leaks and the oil pan left a nice burn on my hand. Well I guess I shouldn't worry Bout it?
post #9 of 13 Old 03-04-2013, 09:49 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
The factory gauge is a pile of chit, The factory gauge stays in the same spot from 165~ degrees to over 225f. Get a real temp gauge in there and let your mind ease
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #10 of 13 Old 03-04-2013, 09:52 PM
Winning DUHHH
Quoted: 8 Post(s)
Secondly, if its hot.....dont touch it lol!
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
