TC lockup switch install help - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-05-2008, 02:47 PM Thread Starter
bryceba's Avatar
I bought a switch from radio shack today to do the torque converter lockup mod. Need help wiring it though. I know its the violet wire with the yellow stripe. My question is about the switch. I bought one that has a light that comes on when the switch is on. It has three prongs. It says they are for load, power, and ground. How do I wire this switch to work for this application?
2001 F250 CC SB
5 In exhaust made by me
DP-Tuner 80 tow, 80 econ, 140 aggressive SWEEETTT
Boost Controller
AFE Intake
Leveling Kit w/ 35x12x16
Projector Headlights
New MB Wheels
bryceba is offline
post #2 of 12 Old 01-05-2008, 03:15 PM
jfines@cox.net's Avatar
I don't think you can get the light to come on with out burning up something.
If I remember correctly.
The load would go to the t/q wire and tap in.
Then you go to ground on the other side of the switch.
With your switch, I think it would put 12v where it's not supposed to be. The ground is to make the light in the switch work.
Jody in Mesa,Az
97' crew cab xlt, F350
7.3L PSD
Long Bed
2 wheel Drive
3 gauge pillar(egt,boost,trannytemp)
3" down pipe
DP Tuner
CAT Delete.
Tranny Rebuid ( 3 disk TQ, extra clutches, all billet steal internal parts, New HD Valve Body, 45,000 BTU cooler)
37' Avion 5th Wheel
jfines@cox.net is offline
post #3 of 12 Old 01-05-2008, 03:16 PM
Strőkër~X's Avatar
try this link, Welcome to guzzle's TC Lockup Mod Web Page
im still alive and kickin...find me on FB..."StrokerX1"
SOLD my truck, another Diesel within 2011
NOTE: if your on OK and need some PSD work done, i know a dealer tech who does the work....PM me!
Strőkër~X is offline
post #4 of 12 Old 01-05-2008, 06:58 PM Thread Starter
bryceba's Avatar
Does the tc wire have constant current running through it when its locked? If so is it positive or negative?
2001 F250 CC SB
Boost Controller
AFE Intake
New MB Wheels
bryceba is offline
post #5 of 12 Old 01-05-2008, 07:04 PM
Powerstroke Techie
djsdiesel's Avatar
DO NOT APPLY POSITVE VOLTAGE to this wire. It needs to be grounded. Go to the page suggested above (guzzles torque converter mod) IMO it is the best one out there. I went to radio shack and got all the parts for under $30 took about 1 1/2 hours to do. Works great and no O/D light flashing.
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #6 of 12 Old 01-05-2008, 07:11 PM Thread Starter
bryceba's Avatar
I will do that mod when I have more time and dough. Would connecting the ground wire and the one that makes the light turn on at the switch make the light turn on? I have no idea about his stuff sorry. I would just like to have a light indicating that its off or on
2001 F250 CC SB
Boost Controller
AFE Intake
New MB Wheels
bryceba is offline
post #7 of 12 Old 01-05-2008, 07:24 PM
Powerstroke Techie
djsdiesel's Avatar
The easiest way is putting a relay in there. That way you can hook up your power to the switch and have the relay put the ground to torque converter wire.
post #8 of 12 Old 01-05-2008, 07:41 PM
I agree with the above statements. And if there was power going thru the wire, adding a light would increase the load on that circuit, causing computer damage. Or it will blead off voltage and the T/Q won't lock all the way, causing slippage.
Jody in Mesa,Az
7.3L PSD
Long Bed
2 wheel Drive
3" down pipe
DP Tuner
CAT Delete.
37' Avion 5th Wheel
post #9 of 12 Old 01-05-2008, 07:49 PM
Powerstroke Techie
djsdiesel's Avatar
Here is a very crude paint shop drawing. Doing it this way will make the O/D light flash when the PCM commands the t/c to unlock and you have the switch on. This is a basic automotive type relay
post #10 of 12 Old 01-05-2008, 08:26 PM
planeoldguy's Avatar
Here ya go.
7.3, Auto., 4x4, 6637, Straight Piped Stock Exhaust, WW, Foilgone.
planeoldguy is offline
