COOLANT LEAK
I have a coolant leak on my 02 and cant seem to locate it. It looks like it could be from the bottom hose but I am not 100% certain. I have had great luck with you guys opinions before and thought I would see if any of you have experienced this before. Also it just turned 130,000 miles and this is the first coolant problem. Thanks ahead of time guys!
Could be the pump check it close.
Our engines were cast in sand and eventually that leaches out of the block and ends up in the coolant and wears the seals on the pump.
where is the pump? Is it located on the front of the block?
Yep sure is follow the radiator hoses right to it
It kind of looks like it is leaking where it goes into the pump. Is there a gasket there or is it just a hose and clamp. I guess I should just try to replace the hose first. Any ideas?
What you really need to do is get your hands on a coolant system pressure tester(including the correct adapter for the coolant tank). Chances are it IS just that gasket. But there's always that chance it could be something else.
thanks for the info. I will try to change the gasket and hose tomorrow. Anyone know of a site that lists parts, maybe ford?? thanks
check the pump inlet and outlet tube the are sealed to pump with o-rings available from ford for about $5 when a bought my truck had a new pump but they reused old orings changed them fixed leak
My leak looks like it coming from the hose on the tank and leaking down and landing just under the battery on the pass side. then it will slowly dribble down and land on the front of the leaf spring and then to the ground. looks like its coming from the hose but not sure. this is on the list of things to do this weekend.
