Newbie needs help with draining batteries.
Hello all! New here.I thought maybe some of my fellow PSD owners might have experienced this....I have a 2000 F250 PSD 4DR 4X4. The batteries are dead in the morning. Both are new as well as the alternator. I can charge them and they will hold fine. I just put the alternator on yesterday, started it, ran fine, parked it and this morning it's dead again. Something is draining my batteries I think. I have searched the forums and couldn't find much related to what mine might be. Where should I start looking, or what is the obvious signs to look for. Thanks!!!
It could be a fuse or relay that runs the charging system might want start there and I'm sure some of the other guys will chime in with some helpful info
Pull fuses, only one at a time and put a volt meter across fuse terminals, you should be able to isolate the problem.
Thanks guys. Where are the chrging system fuses/relays located? Under the dash or engine compartment?
