cold start problems - Ford Powerstroke Diesel Forum
Old 01-03-2008, 04:43 AM
cold start problems
another cold start problem but I couldnt find one exactly like mine.I've got a 99 f-250 and even when it's in the 30's or lower when i let the heater light go out and crank it. It cranks fine but in about a couple of minutes it will begin to idle rough and cut off. A few times when I've been in a hurry and didnt have time to let it warm up enough when I take off it seems to be under powered and will run rough and cut off about the time it shifts into 3rd gear.When I plug it in at night it does not cut off after I crank the truck.Any help would be appreciated.
Old 01-03-2008, 07:36 PM
Maybe the ebpv is getting stuck closed?? When you plug it in the engine is warm enough for the valve not to open.
Old 01-03-2008, 07:37 PM
exactly my thoughts....
Old 02-05-2008, 04:43 AM
Sorry it took me so long to get back to you guys. I unplugged the EBPV and that did nothing but I guess if it's stuck closed would that even matter? Is there a way to check if it is stuck closed short of taking apart alot of stuff? Also the other day when I left work it was around fifty degrees and I hadnt had the truck plugged in and gave it time to warm up. It didn't cut off while idling but after I took off it did the cut off around third gear thing. Then it's hard to crank back up but once it idles a little longer it doesn't cut off anymore but it ran very sluggish like something is holding it back. Thanks for any help.
Old 02-12-2008, 07:19 AM
bump to top
Old 02-12-2008, 07:21 AM
my truck is doing the exact same thing..I just keep it pluged in every night..maybe someone will chim in...
