Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 11-09-2005, 03:21 PM
nbko5v5 nbko5v5 is offline
No Brake Lights - Help
no brake lights, the third light on the roof works though ...
I checked fuses and they are all ok ....
Please help as I use the truck for work pullind a trailer and I already got a warning from the cops about the brake lights not working ...
Thanks
Old 11-09-2005, 05:15 PM
carlopro carlopro is offline
<b>Premium Member</b>
no brake lights
Hey... If you let me know what year and model, I can post a schematic for you.
Old 11-12-2005, 11:58 AM
wiwaniuk wiwaniuk is offline
Go back to basics. Pull and check the bulbs. Do the turn signals work? Check for voltage at the bulb sockets. You already mentioned the fuses are good. If no voltage at sockets, look underneatrh for any damage to wiring. Check voltage at brake switch (under dash?). Good luck, I hope this helps a little .
Old 11-12-2005, 03:18 PM
Thanks all for the replies
I found the problem
A Blue relay underneeth the dash when bad
the relay seems to control all the rear lights functions including the brake lights ....
Thanks again
Old 11-12-2005, 04:58 PM
wesjones wesjones is offline
the two wires you should look for damage on are brown and black with a pink stripe
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
