Batteries - Ford Powerstroke Diesel Forum
Old 01-02-2008, 06:00 AM
Batteries
I dont know if this is a problem or if its common but when i go out to start my truck in the mornings and it was about 13 degrees f with a windchill of 0degrees this morning and when i turned it sounded like the batteries were real weak...but it started...it just took it a sec cause of that...i know cold is hard on batteries...but im just wondering if it gets colder if they will completely fail or what...they are brand new duralast gold batteries...with 1000 cold cranking amps each..TIA guys
Old 01-02-2008, 06:02 AM
I don't know nuttin....
Plug the truck in and let the glow plugs cycle longer before you crank it.
I would have the alternator tested too.
Old 01-02-2008, 09:19 AM
If you have new batterys, make sure all the connections are good. if so then i would lean toward the starer draging. I just had to repace one on my service truck. It was also hard to start in the morning kept getting slower everyday. Put a new one on there and strats like dream
Also something to think about. Weak batts will kill a starter. low voltage means high amps which kills it. If you just replace your weak batts it may have drug your starter down. Hope that helps
Old 01-02-2008, 09:34 AM
I replaced my starter with a gearreduction starter I got at carquest..made it spin faster works great...Oh this was on my 01 psd...
Old 01-02-2008, 10:08 AM
i have had the same problem with my 96er when it gets cold. just not as cold as what you are having. i think it has to do with the glow plugs drawing so much power. use your block heater to help out.
Old 01-02-2008, 06:18 PM
im not sure if i have a block heater...whats the easiest way to find out...cause i cant find a plug in the front anywhere
Old 01-02-2008, 06:31 PM
KVFD
replaced my batteries about 2 months ago and talk about a new truck!! it i will crank like no other. has fast start times and i bought the interstate 870ccamps
Old 01-03-2008, 04:39 AM
bump......
Old 01-03-2008, 04:43 AM
The Fat Mod
plug it in plug it in
Old 01-03-2008, 04:55 AM
If its a 6.0, the plug is behind the bumper, insie the passenger side tow hook hole.
If its a 7.3, i think they are up by the drivers side headlight.
